i don't think so. it is probably 10 years of use. pistons generally roast at full throttle-high rpm. you can't get above 10 mph with i cyl shut off. can you do top end in place? yes. should you? NO WAY!!! once you are to the point you can pull jugs, you are about a half hour's work from having the engine on the bench, where you can see the mistakes as you make them, instead of finding out later.
