prairieboy
So I have a solid 150 in the PTO side but 0 to very low that I reported a little bit ago.
I pulled the rave and it is fine. So I went ahead and pulled the head today. Piston is in one piece and the top ring is there. Can't say for sure if the bottom ring is. Engine turns with no troubles.
Only thing I could see was some carbon buildup and a little pitting on the Piston. The combustion chamber looks really good.
The worst part was some scoring mostly on the exhaust side. A little on the intake side as well. Hopefully these pictures will explain what my dilemma is and with your expert advice is if I should just order new jug and Piston and gaskets from sbt.
Could the carbon buildup from over time have caused the scoring in the walls which would lead to little or no compression?
Sent from my LG-D852 using Tapatalk
