No beep, no crank 2008 230 challenger wake
whiskeyriver
I recently acquired a 2008 230 Challenger wake when to start it up before I took it out anywhere, battery kill switch on, dess on post(new new post and new dess key) , checked all fuses, new battery with 12.4 volts. Power comes on for all accessories but not for depth finder or perfect pass system. I jumped the starter relay, depth finder comes on and perfect pass comes on I get one single beeb, but no crank. Any guess?
ski-d00 is correct. It must be programmed. And after that there is still a problem, these boats have a neutral control switch that prevents the boat from cranking unless the boat is in neutral. Mine failed last year. But I’d start with getting the programming done.
