Nightmare !
Here`s one for ya ...I`m working on this 94 sea-doo xp 657x right..motor ran when i pulled it apart,Just had a busted up cylinder and wouldn`t run good..Swaped the motor last year and can`t get anything out of it except backfire through exhaustand it looks like it`s blowing out through the carbs insted of sucking into the carbs...I have tried every timing mark available and a few of my own !could i have the wrong engine from SBT or can this really be a timimg issue..i`m currently on 147 btdc...HELP...Thanks,,,,The new guy Gary
RV is in correctley..But it sounds like that !..I will check closing..Someone once said Rectafire..Any thaughts ?..Thanks
bad setup
Coul it be a bad setup from SBT, like the crank/flywheel/stator not timed correctly?? Just wondering
the RV is installed just like SBT support said..147 btdc ..How do i check closing ? 65 Degrees ? ANy other timing suggestions for a 94 xp 657x ?is there any differences in the stator/mag/flywheel for a 657...no x..could there be a mix up ?..i have had this ski for a year and a half just for putting an engine in....And i only work on it when i can..i fix about 10 skiis a year and of all makes models ! I have never seen this
in the shop manual
Setting this up is in the shop manual. Do you hav this, if not should get it. As I am sure you are already aware of of, it is all done with the degree well and BTDC setting. I have no idea what the diff is in the 657 and 657x is.
