Zig
We finally got to work on our 95 XP after the kids sucked up a tennis ball and sheered the brass rotary gear. Did everything to spec including torques. Put water to it and it immediately fired up and ran. Idle was pretty high so we shut it down to adjust the carb. Wouldn't restart. Gave it a quick shot of starter fluid. Thought I might have flooded it so I pulled the plugs and ran the motor for a bit without plugs. Tried to restart and it refuses to fire at all.
-Checked for plug spark, good.
-120 psi compression in each Jug,
-gave it a shot of gas in each cylinder,
-replaced the older fuel in the tank with new,
-cleaned the gas filter,
-replaced the gaskets in the carb fuel pump,
-made sure the oil tank was full,
-Battery is at 12.8V.
Any ideas? My next move will be carb kits but the fact that it wouldn't kick with a shot of gas directly into the cylinders makes me think its not a fuel issue?
