Long Short... I acquired a 2005 Sea Doo GTI LE.
Where is the flush valve located on this thing? There are no ports with a threaded hole for the hose to connect. Two drain ports are at the each lower. The blown up pics are the top right inside area of the engine. Thank you in advance!
You'll have to look more closely at your top tube which is the flush port. Someone may have broken a fitting off in the tube. The tube doesn't appear to be broken but in person is better than a picture. Here is a picture from a 2002 GTI LE. At the very least you can PVC glue a fitting on there. I like to fix things as they were designed which means I'd try to peel the broken fitting out of there if that is what I am seeing. Good Luck, Hope this helps.
