Good Morning Folks....Like the heading says....I'm a newbie. My first problem is, I just bought 2 1996 Seadoo SPX's in great shape. One starts and runs fine. The other just clicks when I press the 'start' button. I've took the electrical box out and checked what I could, here is what I found. All fuses are good, when I press the start button the solenoid clicks, but no crank of the starter. When I cross the two terminals on the starter solenoid the starter cranks. When I try and read power on the solenoid, I have 12.5 volts on one side with the lead from the battery and two small red wires and ground. When I test from the other side of the solenoid and press the start button I don't get anything. I removed the starter solenoid and the power in and out, left the little two wire plug attached, put my meter across the two leads, and when I press the start button I have 1 ohm of resistance. So to me the solenoid is good and my MPEM is bad, but, what do I know....like I said I'm a newbie. Please Help! Ken in Tucson
