Luv2Camp
Hello all.... Just got into the PWC world at 44. Picked up a 1995 GTX that has the DESS upgrade when it was new. I am the third owner and the prior owner had it for 12 years. Dealer advises that there is just 100 hours according to the module... Runs great but does have a leaking RV gasket so it does smoke when first started. My kids are having a blast with me pulling them on a tube with it. I am going to pick up a set of ski's for me soon as well. Picked up a wealth of info from here so THANKYOU!!!!!
So far, I have...
Added the Jensen ms30 gauge stereo (mounted it under the reverse handle, needed a 3" hole) also added Pyle marine speakers and mounted those to the side (just above the hollow area where the fuel tank is)
Replaced all fuel lines with Gates fuel lines
Replaced the fuel selector valve
Replaced the fuel float
Replaced all zip ties and added many more to keep everything tight and tidy
Replaced spark plugs, caps and ignition coil
Replaced the fuel cap gasket
Removed the carb and cleaned the filters
Replaced the spedometer sending unit
Added an Aqua Step
Complete oil system flush as previous owner was using any old 2 cycle oil
Oil filter replaced
Replaced the handlebar grips
Added a Blacktip handlebar cover
Replaced the started relay solenoid
Welded new aluminum plugs to the tuned pipe and painted the entire exhaust
Installed a tach/hour meter
Installed a clock
Replaced every hose and line (oil/bilge,cooling, etc)
So far, I have...
Added an Aqua Step
Oil filter replaced
Installed a clock
