97explorer717
First of all hi to everyone. I am about at my end. I got a 97 explorer a couple weeks ago. It had been sitting 2 years. Pulled motor, fuel tank, cleaned, all new lines, fresh rotary valve bath oil and premix. Took it out and ran great about 5 mins then started hearing a whooshing sound. Took it home, checked over and ran on hose. Did not hear or see anything. Went back out on the 4th and it started not wanting to plane. Got back and wear ring was chewed up BAD! Tonight I installed new bearings, impeller shaft and wear ring (all from sbt). When I reinstalled the pump it was so tight the motor would not turn over. I then loosened the pump and it fired while shaving some of the new wear ring out. I ended up having to start the ski and slowly tighten the pump. It shaved a uneven grove in the new ring. I have looked inside the pump while its running and it looks to be spinning straight. Any thoughts would greatly be appreciated.
Just a little history, this is my first jet anything or seadoo. I purchased a 95 Explorer and had it 3 months before loosing the bottom end (9yrs old sbt engine). Did the same maintenance as above for the 97.
