Ok sorry if this is a long post but here it goes.
I have a 1996 Seadoo SPI. It ran great the first year we had it. (we bought it used about 7 years ago.) Now everytim you take it out on the water and put gas in it , it will bogg down really hard under throttle BUT when you take the seat off, it runs fine. It will do this for about 10 minutes and then it runs fine. While inspecting the ski a few nites back I found that the neck on the fuel tank for the inlet hose is broken, therefore fuel is spilling out into the hull when you fill it up.
My theory (which probably doesnt amount to much since im pretty much a newb): The engine is starving for air. All of the fumes build up inside the hull and the motor cant get clean air. Once the fumes are gone, it runs fine. Could this assumption be correct? Or am I pi$$ing in the wind?
Either way, Ive replaced the fuel tank and now I cant get any fuel to the carb. Ive checked all of the hoses. None seem to be pinched or blocked. (this is the first time this year Ive attempted to start the ski. I guess I need to find the fuel filter (not real sure where its at) and try to replace it. I cant even prime any fuel into the carb.
Any and all opinions are appreciated. TIA for the help guys
