Hello,
I recently bought a 2007 challenger 180 with 71 hours on the boat (according to the display). The boat has a little bit of a starting issue. It first happened two days ago after being anchored for awhile. The boat did start, but a low battery voltage came up on the display after finally starting. Today I hooked up the battery charger to the boat and it again had trouble starting, but did start after 5-6 attempts (held down the start button for 4-5 seconds on each attempt). The RPMs when cranking was about 450. Does this sound normal? I have already replaced the spark plugs, which did not resolve the issue. The low battery voltage did not appear on the display after starting. Anything I should look into first when trying to track down this issue?
I also have an issue where the RPMs are varying when the boat is running at any throttle. It was varying about 100-150 rpms (so it bounced between 4500-4700). Since changing the spark plugs it bounces around 70 rpms or so. Is this normal for this type of boat? Anything I should be looking into? This is our first jet boat, I'm more used to outboards.
I plan on having the SC rebuilt in the next week or so (really hard to do with all this nice weather we're having, but I heard they're a time bomb!)
Thanks in advance!
Thanks in advance!
