New to forum B2220 code fault
Zman55
Hey guys This is my first post was looking for some help!
I have a 2009 GTX iS 255, took it out on the water today and everything was fine then I hit a wave and check engine came on and the red IBr light and ski would only go 20-25 mph with throttle all the way day, it would take some time to even reach 20mph, I took the key off waited a minute and everything worked normal, so I let it rip and hit about 55mph and then the ski slowed down with the error, b2220 right keypad, it would still go 25-30 but again took some time to build that speed, I'm kinda worried that I might of sucked something up when I launched is there any way to tell without taking stuff apart I'm not very mechanical
Also on a side no is that anyway to unstuck some of the buttons on the handle bars set seems pushed in
Any help is greatly appreciated!
Zman55
NY Long Island
I have the exact same ski and had the same code. I bought the right keypad for $87 and changed it. It is easy. I also got the new rubber button covers for start and cruise. Keypad comes complete w/ rubber buttons. I don't think the code will affect performance. I had the code until I changed it with no reduced speed. Has supercharged been rebuilt? If not take it in and get it done. I just learned the hard way, I tried to get a few more ride in and washers and gear broke and went into engine. All fixed now $1700 later.....
Where do you recommend I buy the key pad and buttons, also I only have 40 hours on the ski you think I should rebuild super charger? How easy it is to change key pad
