New to boating
lfemat
Hello, I just bought a 2007 Speedster 215HP SC with 30 hrs of use
I have been doing a lot of reading in this forum and i have some questions about my boat:
1 is it normal to go all the way to 8000 revs when I accelerate pulling a skier?
2 some white smoke appears on the back withc from my readings is normal, how much smoke is normal?
3 some times i get the beeping alert and in the dash the message exhaust overheat appears
4 what is cavitation?
Hope some of you guys can help me
Femat.
The official definitions of CAVITATION are:
The formation of an empty space within a solid object or body.
The formation of bubbles in a liquid, typically by the movement of a propeller through.
In the case of our jet ski's, it is when the impeller spins but doesn't really grab the water all that well. It can be caused by a damage impeller (Bent blades), a worn wear ring (what the impeller spins inside of), or chunks in the impeller.
You will get HIGH revs with poor performance. It will normally eventually get up to a decent speed, but not like it should. It could take 3 to 5 times as long to get near the top end if it reaches the top end speed at all.
Hey man welcome too the forum!
There have already been some good posts here and I'll try to add a bit more information to help you out.
1: It can be normal to hit max rpm's when towing during the initial take off, but it can also be a sign that your propulsion system needs maintenance. Even though the boat only has 30hrs, it is over 5 years old and things deteriorate over time as well as usage. If you are experiencing cavitation (see answer for #4) then the boat will rev very high during hard acceleration until you get on plane. It all depends on what you are towing, how much weight and how many you are towing. I have the 155hp version of this boat and I can tow 2 tubes with full size adults with little problem or cavitation during take off. I have never tried pulling more than one skier, but depending on the weight and skill of the skier, it can take a bit of time to pop the skier up.
2: White smoke coming from the exhaust port at the rear of the boat is normal. These engines inject sea water into the hot exhaust to cool it so the exhaust pipes do not melt your boat. Doing so causes the water to turn to steam which exits the boat as 'white smoke'. Perfectly normal when the boat reaches operating temperature.
3: Beeping alert and hot exhaust is problem that needs to be solved before you use the boat any further. Ignoring this can cause expensive damage and may even melt parts of your engine compartment. It can be many things including, faulty temp sensor, blocked or partially blocked exhaust cooling system, propulsion system cavitation.
4: See this thread about how a jet pump works and cavitation: http://www.seadooforum.com/showthread.php?4959-quot-How-a-jet-pump-works-quot&highlight=jet+pump+works
In a nutshell, cavitation is the jet pump loosing compression and sucking air. If air gets in there, you loose propulsion and the water/air mixture just spins around in there like a blender. Feels like a transmission or clutch slipping on a car, you give it gas and engine revs but no go. During cavitation, since there is very little propulsion, there is also very little cooling water being sent to your exhaust system which can cause it to overheat. Hopefully you can seen now how this is all interrelated.
If I were you, I would start by taking a close look at my propulsion system. Inspect the jet pump, impeller, wear ring, bearings, and drive shaft carbon seal. Any and all of these things could need replacement and would cause cavitation. There are lots of threads about this stuff so you may want to begin by doing some searching and reading for more info. You can also download the shop manual for your boat and engine to see how to diagnose these things and do the maintenance yourself. If you have a decent set of tools and some mechanical know how, you can do most of the maintenance yourself.
Good luck, let us know if you have any other specific questions.
yes, what he said.
also, welcome to the forum and you bought a great boat. That little thing with a 215 will scream. You should find a good mechanic/shop and have it serviced, around $270. That way they'll check over everything and let you know where you stand. Good luck and enjoy it.
Thank you all for your comments, they are really useful, I´ll start by checking the propulsion system an go from there.
