Richiespeedster
Hi, where is the hn number which i believe gives me the year?
I have just got the port engine started so that one does run so surely the fuel must be ok,
I can't get the other one to even cough!!
I tried swapping the leads over from the side of the ecu on the working engine in case there was no spark but I don't know if that would work? it didn't anyway! made no difference,
I don't have a compression tester but the non runner is easier to turn over manually than the runner, yet the runner turns over much faster on the starter! very strange!
both turn over on the starters but I don't know if the non runner is sparking is there an easy way to test for spark??
where should the fuel taps in cockpit be?
so obviously being easier to turn it means it's low on compression, can this be anything other than a worn ring or knackered engine?
thanks guys I hope you can give me some hope
Richie
Richie
