Hi all,
I just bought a '03 GTX Supercharged and I've got a bunch of questions. First off, I bought this because I got a great deal on it. I wanted to be able to have it pull a 230lb skier up on 1 ski. And I wanted a comfortable cruiser. I've read on here some say to avoid the supercharged version, but at this point I would just like to make sure it stays reliable.
Here goes:
It's not my intention to be driving crazy and flip the thing, but I would like to know in the event of a tip, is their a specific procedure to follow. I know kill the engine (which should happen when the cord pulls off) and flip it back up asap. But is their a specific direction it should be flipped back up? I remember from ones I rented (Yamaha) that their was. Also, should it not be started until the plugs are pulled, WD-40, etc?
What maintenance items should I make sure I do? It had 56 hrs when I got it and it now has 60. He said all updates had been done and it had a fresh oil change. It's got a Riva state 1 kit. I want to keep this as reliable as possible.
The wear ring needs to be replaced and he included the OEM part. Should I attempt this myself or leave it to the pro's? I'm fairly handy, but I not a mechanic.
The steering is tight and he included a new cable. Should I attempt to change this myself?
I would like to have the option of pulling it with our Pontoon (either on the side or from behind). Does anyone here have any good advice? If towed from behind, I assume I'd want a solid line so it would not coast into the motor if I stop. For the side I could do a rope line, but what combination of bumpers should I use to make sure there is no damage to either one? This would just be idle or very slow driving, however with a lot of boats on the lakes, the water can get very choppy.
It doesn't have a fire extinguisher strapped in up front. Are they required?
What jacket/vest would you recommend?
Any general tips for a new owner?
I'm sure I'll run into more stuff down the line. Thanks in advance for everyone's help!
Here goes:
