terrick619
I just bought a 2000 challenger 1800 and I was wondering I could get some things clarified.
I don't want to put my trust in the previous owner so i was planning to do the following:
Remove the impeller and lube the shaft.
Replace the impeller and stator lubricant.
New Plugs.
Rig engine for premix.
Install all new plugs and check compression.
Replace fuel filter
Replace water separating fuel filter
To do all that, the only non home depot tools would be the compression tool and the impeller shaft wrench correct?
Am I missing any other actions I should take?
I've read seafoam is bad but what about the mercury power tune engine cleaner is that worth doing?
Last item, I've read on the forum but have yet to find a suggestion on what surge gate to use and where to get it? Currently there is the original and I would rather replace it with one less likely to break.
Thanks
New Plugs.
Replace fuel filter
Thanks
