I've been a boater and shade tree mechanic for years maintaining and repairing my own gear, mostly OMC outboards, Mercruiser sterndrives, etc. Last week I entered the world of PWC's and picked up a 1996 GTX with the 787 engine. This ski had been sitting in a garage for 10-12 years with a factory cover on it. Best I can tell from the gauge, needs new polarizing piece, the ski has 156 hours on it. After dragging it home and doing a visual inspection, I pulled the plugs and dumped some seafoam in the cylinders for 24 hours to lube things. I drained the fuel, put in all new fuel lines, checked compression (was ~125-130 cold, before starting, on my cheap HF gauge) and cleaned/rebuilt both carbs with true Mikuni kits. Installed a new battery, poured in some fresh non-ethanol fuel, added oil to the tank (had a bit in it) and it fired up in short order and seems to idle/run well. Discovered that one of the welch plugs in the head pipe has a crack, so I threw a wrap of tape on it so I could head to the water to test it. Also have picked up the stuff for a drive oil change.
On the water, it had heavy 2-stroke smoke for the first 3-5min, then got to what I would call normal. Ran it conservatively for a bit, eventually racking up an hour or two of run time. I did a couple full throttle runs after a while of break-in and getting familiar with the ski. The info center registered 55mph, so I'm guessing it was really maybe 50. Given that speed, I'm thinking the engine is running well on the top end.
Here is what I have come up with so far-
1- Ski seems sluggish until about 3000 rpm, then, right before it comes on plane, can suddenly accelerate very hard. I expect this to a degree, but the difference is VERY apparent. It's almost like it switches from low speed jets to high speed. It runs well at the lower RPM, but I'm not sure if there should be more power there, or if this is the nature of the beast. It seemed to make no major difference if there was one adult or two on board, it was about the same feel.
2- Should I clean the RAVE valves out or do some kind of maintenance to them?
3- Has anyone tried using the propane torch melt aluminum welding rods on these exhaust plugs? I have the pipe out and cleaned, ready to fix, but finding a tig welder isn't likely to happen for a while. I've searched, but haven't seen where anyone tried this, but I'm sure it's been done before.
4- The gas gauge isn't working. Can I release the tank straps, remove the 4 fuel lines, and just slide the tank forward to get access to the sender?
5- While in changing the pump oil, anything else should I check?
6- Reinstalling the head pipe, is copper Permatex RTV good to use for the flanges where the circle clamp goes, or should I use Loctite 518?
7- The oil lines are the same grey as the old fuel lines. Should I change them as well?
Sorry for all the questions. Looking forward to
