I am new to this forum.
I have 2 Seadoo LRV 2001 models. Carb engines.
One has MPEM with broken pin#7 on the #1 plug. My info gauge does not display but ski runs well.
Switched out the MPEM from the other LRV and the gauge works as it should and the ski runs well.
Both MPEm are # 278-001-398
I purchased a "new" MPEM 278-001-525.
With the new MPEM installed I took the ski to the lake. Guage now works as it should. After about 2 minutes of run time idling through a now wake zone the motor quit. It would start but only run for about 2 seconds.
Plugged in the old MPEM and the ski ran fine. Again this is the MPEM with pin #7 broken off so the gauge does not work. Ran the ski for 1 hour with no problems.
Re-installed the new MPEM and the same thing. Only this time I was in the middle of the lake and could go full throttle. After 2-3 minutes the same thing happen. The engine quit. It would start again but quit in 1-2 seconds.
I would remove the DESS key and plug it in again. Two beep as normal - restart and the engine quits again.
Put the old MPEM on again and it ran fine.
Any ideas what to do?
Thanks for anyone who can help.
Daniel
Daniel
