i just joined the forum today as a premium member.
I recently bought a 1998 XP in great shape from a close friend - at least I think it is a '98 XP - the hull number is ZZN72659A696, and the engine # is 4635930 Type "787". I bought a new battery, replaced all fuel lines, rebuilt the carbs from top to bottom, cleaned all harness connections, lanyard, DESS post. I also removed the starter and took it apart and inspected it internally, etc. I basically went through the boat from top to bottom. I am extremely mechanically inclined - been working on cars and outboards for almost all of my 50 years!
I rode the ski for the 1st time last Saturday - it ran great! Faster than heck!
However, Sunday afternoon, went out to start it - put the lanyard on - heard 1 long beep and that was it. after reading some threads on this forum, I tried a recommendation. This involved pulling the lanyard off, hitting the start switch 5 times. When I did this, I re-installed the lanyard, got an extremely short beep followed by 1 long beep. Then I hit the start switch again, and got 3 short beeps. I have repeated this cycle over and over again to no avail - same thing happens each time. I have also checked all connections and grounds inside both the front and rear electrical boxes, starter switch, etc with an ohm meter. The previous owner said anytime this happened in the past, it was a weak battery, However, my battery is brand new and fully charged. Also, I have even hooked up a KNOWN good full sized marine battery from my full sized boat and the symptoms persist.
What does this mean? Can anyone kindly help? Perhaps I can return the favor with some OMC (now BRP) and Yamaha outboard knowledge! Also, if someone can verify the above VIN's for the model and year that would be great, too. Thank you in advance!
