Sorry I posted this in PWC by mistake, maybe that is why I did not get much of a response. Lololol
Ok after reading pages of different post I am confused on the whole oil issue. I have a 2005 Seadoo Sportster LE DI with a 951.
1. Is the crank case oil the same thing as the counter balance oil?
2. I was told the case gets its oil from the 2cyc oil as the engine runs?
3. I have seen pictures of a 6mm plug on the side of the engine for draining the oil with suction, is this correct?
4. Is their a drain plug and fill cap on my engine?
5. What oil do you fill it with and how much?
Different issue:
I removed the pump to change my wear ring and when I removed the cone from the impeller it was full of water, not oil, not milk colored oil, but water. I ordered a new wear ring,cone o-ring, and what ever else is between the impeller and the pump housing. I also ordered the impeller removal tool and I used the site supporting vendor. The impeller still spins good, does this mean the bearing is ok or should I replace that also?
Also what about the fuel pump piston? Do I need to check anything on this or do any kind of maintance?
no I do not have a manual, and yes I have gone to the manual link but they do not show a manual for my machine.
Different issue:
