MontanaXP
I replaced my flywheel assembly and starter clutch and tried to fire up my '94 XP and it cranked over fine then after a few moments it let out a loud WHOOSH! out the exhaust. I checked for spark and both cylinders are firing, it's not getting much fuel but if I keep cranking it keeps 'backfiring' or makinging that sound like it's letting all this compressed air out the exhaust.
Before I changed the flywheel it ran great! Then the starter gear on the flywheel slipped back and locked the motor when I shut it off. Replaced the flywheel and such now it turns over fine but won't start (or even try). I used the rope in the spark plug hole to remove/replace the flywheel and torqued it to 100ft/lbs. Rope came out fine and didn't seem to have caused any problems...is this just a timing issue? If so how can I get this thing running before the snow flies!
