New Driveshaft Seal & Aluminum Thru Hull Install "Video Included"
cheappc
Wow!
Thank you Dr. Honda and OCOD, and all the wonderful people here at Seadooforum.com! this site is awesome! With all your help and encouragement I installed my new driveshaft kit (aluminum thru hull, protectant hose, all in one seal).
I learned a trick on how to get the boat on plane all the time, I know Dr. Honda this is a no no for you, since I read your posts on someone else post. The problem I have is that my boat bogs down if I try to apply the throttle too fast, and sometimes it just dies back down.
So, this is the first time I learned this trick, which I read somewhere its bad to do, but what I did to "pass" that point where my engine bogs down, is pull the choke lever a little bit, and here the engine rpm go up, and finally i can go on plane whenever I want to!
Now I did read that this is bad Dr. Honda, running to lean or rich condition and can blow your motor out, here is a video:
[video=youtube_share;J4brHULXhPo]http://youtu.be/J4brHULXhPo[/video]
The driveshaft seal worked like a charm by the way!! thank you!
