So got my new WSM crankshaft today and when I drop it in the case with counterbalance shaft I am getting a little gear noise when rotating by hand. No noise when rotating crank or CB shaft alone in the case. Is this normal ? I don't feel anything binding. Only reason I am concerned is the vendor I bought it from mentioned to check for lash between the gears when installing new crank. Evidently they must of had issues with past WSM cranks. Comparing to old crank, teeth of both gears appear to mesh about the same. I will call vendor in the morning to get his thoughts
