simplewon
Just bought a speedster. One carb was stopped up but at 2800 I figured I could fix it.
Got the carb dissected, dipped and cleaned then reassembled. Went to the lake, quarter tank of gas, it was not gas, mostly water in the tank. Cleaned out the tank last night with a 12 volt remote fuel pump, removed the carbs, sprayed alcohol with oil mixed in the engine, before disassembly to prevent rust from the water.
The boat was demo'd in normal fuel mode, I did not add fuel first time to the lake wanting to burn out the old fuel. I switched to reserve and sucked both carbs with water. Ouch.
Questions: The boat only came with a white lanyard. Is this the learning key or does the yellow and white rule not apply for 97?
What gps speed should I expect out of it, pure stock?
The manual like at the top of the page, if I pay 11 bucks, is it one manual at a time or can I then download the owners manual and the service manual or do I pay 11 bucks twice?
Thanks for all the info.
