Hi
I started this thread (link below) last year about performance problems with my 05 Challenger 180 SCIC:
http://www.seadooforum.com/showthread.php?t=14042
Time has passed since that and several parts have been replaced. Performance has improved greatly but I'm still not completely satisfied.
Please look at this youtube-video: http://www.youtube.com/watch?v=wv7EmnREuZY
You will see me go WOT from about 3000 rpm and the engine will instantly reach 8000 rpm. This is only possible when I'm the only passenger and the fuel tank is below half. If I put any extra weight in the boat I have to be very gentle on the throttle, otherwise it will just bounce of the rev. limiter. After I reach adequate speed you will see me reduce to 1/2 throttle and the engine will do about 7000 rpm. At 3/4 throttle I'm back at 8000 rpm.
This is what I have done so far:
Replaced wear ring and impeller
Replaced the neoprene seal between pump housing and hull.
Removed and polished the drive shaft.
Replaced the drive shaft carbon seal.
Is this really the way the boat should behave or can I expect better performance? If that is the case, what more can I do? I've been thinking about replacing and resealing the pump support as the next step but that’s a lot of work and I want to make sure that it’s the only thing left to do.
Best regards
Erik
Sweden
Best regards
Erik
Sweden
