Hi,
I've got a 99 Seadoo GSX Limited 951cc, over the past month, I've been through two batteries.
I purchased this jet ski approximately 7 months ago, and only about 2 months ago, its started to give me issues with the battery, the original battery that came with the jet ski when I purchased the jet ski died 2 months ago, I replaced this battery with another, after installing the first battery, it was running smooth (just like I bought it) for about 2-3 weeks and then it just wouldn't crank, I charged the battery, and it started, so left it on for a while to let the battery charge itself, came back the following week to take it out, battery was dead, only had enough battery power to bring up the display after the key was plugged in.
I then took the battery and exchanged it for another new replacement which is exactly the same. I installed it in my jet ski, waited about 20 minutes and it started with no problems, after 3 weeks.
I took it out for a ride and it broke down in the middle of the water, took a while to get it turned back on while stuck in the middle of the beach, it finally turned on but would only idle at 500rpm-2000rpm, turned out to be a spark plug, it was only running on 1 cylinder after it broke down, managed to get the engine started on 1 cylinder and limp it back.
I then replaced the spark plugs, and now when at idle it will it burns more than usual oil and idles at 1,500rpm when outside of the water, it revs easily to redline, but not as responsive but I blame that on the idle, I've noticed the negative terminal seems to be badly corroded, so first things first.
What would be the easiest way to change this cable? It looks like it goes under the engine?
After replacing this cable, I'm going to start it up, and check to see if the battery is being charged by the alternator using a multimeter.
