R r3cc0s Member Aug 31, 2020 #1 Had the motor rebuilt bottom up - the current brass ring is leaking a "bit" not tons but enough to leak exhaust and some water. Can't find this thing anywhere... any suggestions?
racerxxx Moderator Moderator Aug 31, 2020 #2 Is that the copper washer in the exhaust? If so, did you use high temp rtv?
R r3cc0s Member Aug 31, 2020 #3 racerxxx said: Is that the copper washer in the exhaust? If so, did you use high temp rtv? Click to expand... no just clamped it back together - didn't see any silicone on it
