Hello everyone,
Heres the run down of what i have going on, I have a 2001 GTI with a 720 and a single 40i-38 carb. I just rebuilt the motor and carb, put it all together fired it up and it idles fine but as soon as i would tap the gas it would die. After some investigating i found that the accelerator pump was not working. There was so much crap in there it was not repairable. So I looked in to replacing it but they want over 200 dollars for it
I talked with a mechanic at a local shop to see if i can just rejet and not use the accelerator pump, we looked it up and a 97 GTI is the last year of the non accel pump carb and its a 40i-38 also. So i rejeted to those specs boat runs good but im stuck on something, if i gradually increase the throttle it pulls rpms fine but if i go from idle to full wide open it bogs and will even die? I thought i knew what i was doing but im pretty much lost at this time. :banghead:
specs
pilot jet- 70
main jet- 175
n/s- 1.5 with silver spring
lsa- 1 turn
hsa- 1.5 turn
specs
pilot jet- 70
main jet- 175
lsa- 1 turn
hsa- 1.5 turn
