I need new oil lines on my 95 Speedster. The little ones under the carbs are brittle. What size are they? Where do you get them? What kind of clips do you use to secure them?
3/32 tygon fuel line. I got mine at Lowe's in the weed eater section. Secure with zip ties.
When your done, spray premix in the carbs and hold the oil pump lever to full on. NOT THE THROTTLE. Watch with a mirror while the oil lines fill. Might take a couple of attempts to fill completely.
I say premix cause you don't want to run engine on gas only. You could also fog engine through spark plug holes, start, fog....., but premix is easier. Should only take about 1-2 minutes
