This 96 was serviced at dealer in april of 07 then put in garage, I purchased from a family member. Replaced Battery with new, Drained gas, cleaned fuel filter. Put new plugs in it.
When you hit the start button motor turns over, got good spark, does not fire off. I have taken the air cover off, poured gas down carb and it will run till it burns that gas off. I have pulled the fuel lines ran air through them not clogged. I have pulled fuel lines tried starting and fuel trickles out of hose.
Where do I go from here? I've got to think this is some kind of fuel problem but I'm stuck. Previous owners always had dealer do all work every year. I can't afford that.
Thanks for the time and help
