Hmmm..........it appears on this boat (98 sportster) they weren't connected to any tubes......maybe used on a different model? So I assume it wouldn't affect the pump it they were blocked off, correct or no?
I'm curious........what do they siphon and on what? I don't have my jet ski here to look at.
Oooooh so that's why I can ride around after forgetting the plug and not sink.
You must not stop long for the water to come in the PWC with no plug. This did make me laugh.. The boats don't use them so you are ok. You should have bilge pump in your boat. I would make sure that works since if you forget the plug the OEM pump is not strong. you might have a bad day.
A lot of the parts are interchangeable between the skis and boats. My boat has the holes for the bailer in the pump, but doesn't have the thru the hull tubes. My squiters on the ski have 2 holes, but only 1 is connected. On the boat, they are both connected (twin engine).
I like the fact that some of these things are interchangeable, keeps the parts price in line and available.
