grusnak1001
When I remove bucket to view fuel selector from the underside, I can not even see it (let alone remove and replace). Can anybody give me some clues how to go about replacing the fuel selector??
Thanks for replying Popps, I'll try this and hope for the best. By fuel/water seperator, do tou mean the fuel filter assembly? And by the inlet hose, do you mean the thick hose running from the place you pour the gas in? If so, now I can see why I could not see anything. I'll keep you updated.Remove things in the way...fuel/water separator
...inlet hose for the tank...etc,,,i am talking in generalities,,,the goal is to remove the selector with the hoses attached,,,,disconnect the inline to the carb so thst it remains attached to the water separator,,,,,you want to be able to lay the whole unit on a table,,,label your hoses carefully,,,replace one at a time,,,take lots of pics,,,
On top of the ski,,,remove the rubber cosmetic rubber plug,,,underneath it is a small phillips screw,,,use the correct screwdriver,,,pry the black selector knob upwards,,,don't lose the little phillips screw,,,and the tiny washer,,,loosen the black plastic hex nut,,,with your hand under neath,,,you can pull the selector down and out,,,please take note of the orientation of the selector,,,hose orientation,,,etc...so you can put it back without stress,,
once again,,at the beginning,,, remove or pull to the side any hoses in your way,,,
if a hose won't come off the barbed fitting,,,cut it with a knife,
Let us know.
Update...as I was beginning to explore what is involved in replacing fuel selector, I thought I would check the fuel/water seperator. The first thing I noticed was the threads were stripped and would not tighten. The second thing I noticed, when I took a look inside, the rubber o-ring was stretched and could not fit properly. (backing up a bit), the reason for wanting to replace selector, is that the boat would shut down at higher speeds. When I put it back, she started right up but died and would not start so I'm guessing this might be the problem.For now, I am going to replace the fuel/water assembly to see if this solves my problem. I found one on ebay (brand new) for $20. If you have any thoughts or recommendations, I would appreciate hearing from you. Thanks again!
Well, I'm hoping the F/W assembly will fix my problem, but I'll keep that in mind if it comes to replacing selector....By the way, do you have an opinion on a plastic v.s. aluminum selector? I heard arguments on both sides.Also...when you are putting clamps on the selector,,,take note if the clamps prevent the selector from sitting flush with the top deck,,,that happens to me often,,,
Good info pops ! Now I know the the one on my ski is probably Chinese - is definitely out of phase.If you are able to find an aluminum one,,,I would get it,,the chinese knock offs sometimes have the selector being out if phase 90 degrees ,,,that is,,,reserve does not point to reserve,,,etc...
Ok, I replaced fuel/water separator, and it would not start (it turned over though). I thought it was because I forgot to fill fuel/water separator with gas, but when I unscrewed the cup, it was full. Any idea what's going on here Popps?Update...as I was beginning to explore what is involved in replacing fuel selector, I thought I would check the fuel/water seperator. The first thing I noticed was the threads were stripped and would not tighten. The second thing I noticed, when I took a look inside, the rubber o-ring was stretched and could not fit properly. (backing up a bit), the reason for wanting to replace selector, is that the boat would shut down at higher speeds. When I put it back, she started right up but died and would not start so I'm guessing this might be the problem.For now, I am going to replace the fuel/water assembly to see if this solves my problem. I found one on ebay (brand new) for $20. If you have any thoughts or recommendations, I would appreciate hearing from you. Thanks again!
