skipper6567
Hi All, Thanks in advance for any help. I will try to keep this short and still give all info. Sea Doo utopia,2.5 sportjet,
oe405933. The engine starts and runs. It does not have any power as you move throttle. The rpm does not increase as it should after 1/3 open. It stays running throughout the entire throttle range. The throttle is working,plates open, trigger moves advances timing.?not sure if getting full advance. No major work done before problem started. The rpm max is 3k whether throttle is 1/2 of full. No real changes in performance from 1/2 to wot. Parts that have been checked and/or replaced :TPS new and within voltage specs. Stator new, several coils[cdm] .both head temp sensors, ignition pack. I have spark on all cyls,checked with digital rpm/time gun,all cdm reading +-10rpm while idle and up to 3000rpm. voltage is 15.5 while running. Have not changed rpm limit box.?? I did link/sync and now idles at 1100 instead of 1600 out of water. Burning lots of fuel!! oiler rod adjusted. Time light looks like 8 btdc at idle with all connections done. The plugs seem to be wet/oil when checked at least 20 times!! 28 psi fuel pressure,idle and running. Air temp sensor checked/changed,map tube clear and connected. I marked the flywheel and can watch all 6 fire with light. There seems to be a stumble, randomly at idle and time light you can see it miss for a split second. the flywheel outer magnets were loose and some cracked, all attached now with epoxy. The trigger and rpm limiter is one of the last parts that I haven't changed. The spark jumps 7/16 on all. Full throttle it sounds like bogging,but I can hear it and feel it surging like it wants to go. This problem just happended all of a sudden. I have run it off external tank,changed filter,checked lines,vst tank. Could trigger breakdown give these symptoms. Timming doesn't just go way off..? without screws moving or bad trigger. Ive checked the fuel injector circuits. If there is problem with injectors its all 6 at once? seems unlike. It is the engine not pump issues. What am I missing?? the ecm?? I tend to say no because im getting that light surge split seconds at wot. Im using lots fuel.Leaning towards injector pulse duration?? I will be standing by for one of you merc guys to tell me the stupid little item that Ive forgot..ps compression was 135 all 6 holes.Thanks Again. Skipper
