paulmac201
I purchased a 2013 GTX 260 Limited IS last fall with 92 hours. I took it out on the lake and within the first hour it lost power. It went into limp mode at first and then went completely dead.
I took it home and started troubleshooting. I then started parts swapping including a new ECM. Still dead.
I started shaking wires going into the ECM a few days later and it lit up. I have isolated the problem to the “B” wiring harness bundle that connects to the ECM. It contains the brown/yellow wire that goes to the starter solenoid. It also contains the black, white/grey and black/yellow wires that go to the DESS. I tried to wire tie the bundle of wires so they can’t move but then I lose all power like it did on the lake. I removed the wire ties and pushed and pulled the wire bundle and the power returned. Moral of the story is I can’t tell exactly which wire is the problem and whether or not the bad wire is in the connector going into the ECM or somewhere down stream.
What should I do? Should I replace the entire wiring harness? Are there diagnostic tests that can be done on the existing wires?
Any and all input is appreciated! I have officially hit a brick wall.
Thanks,
Paul
Thanks,
Paul
