PhongRacing
Hey guys need your help diagnosing a problem with my boat it’s a 2008 230 wake with twin 215 SCIC motors, had the boat out yesterday in the river all day towing skiers and tubes boat run very good but at the end of day going back to the dock had to idle thru a 1 mile no wake zone, went to get back on the throttle and noticed the port engine would not go more than 4500 rpm and would not build any boost (I have boost gauges installed on both motors) luckily I was at almost at the dock, loaded it onto the trailer, opened up the engine cover, did a quick visual inspection to see if any hoses or lines came off, didn’t see anything out of the ordinary. You think I’m going to have to remove the supercharger and check the washers? If the washers did go you think I did any engine damage?
Any help would be appreciative
Thanks in advance
Thanks in advance
