need help changing steering cable on 99 gtx limited
xp537
I Have Never Changed A Steering Cable its on a 99 gtx limited What Is The Process The Front Looks Easy Its The Back That Im Not Sure Of .Do I Need To Remove The Pump To Get To The Plastic Nuts Any Help Will Be Appreciated
steering cable
i did my spx and i just loosen the jam nut off.cut the cable off short and had to hammer back about a half inch ,then push the steel ring foward ,allowing the plastic peices to come apart.then just pulled the cable back threw. hope that helps
