Need help 2000 seadoo rx bogs stalls
jmyers
Hi i have a 2000 seadoo rx that I recently took out when I went to give it gas a little bit it started up on plain then when I give it full throttle it bogged down and stalled out it idles fine in the water when it is on the trailer you can give it throttle and it runs good but when there is a load put on it in the water it bogs and stalls out when given full throttle if anybody has any advice let me know please help.
what up myers....
possible the carbs need attention, and/or reeds needs replaced, but a quick elimination, is remove/unplug the yellow and red wires/s from rectifier, and if lake/ocean aint far, then give a quick run, if problems solved, replace the rectifier...:cheers:
Accelerator pump?
Your model has the accelerator pump on the PTO carb that injects a shot of fuel into the throats of the carbs on that initial "jump down" on the throttle. The brass elbows at the carbs, where the small fuel lines connect will gum up, causing the pump not to work correctly. I'd say, take off the air box, look into each carb and pull on the throttle, see if you can see that squirt of gas being shot into each throat............:cheers:
