robin savell lloyd
I took my brothers kids out today and after 1 hour of tubing the cooling system cloged up and the after market exhaust system hoses melted and came apart. this is one time I am glad that I use the very exspesive oil to help the engine to make it threw these hard times. I checked the water line coming from the pump and there was water flow going into the engine but none leaving the engine. [It seems to be 100 percent blockage] I reversed the lines to back flush the engine but when I hooked it back up correctly there was still no water flow. So I took a chance and hooked up the water lines in reverse[ back flush ] and I was able to make it back to the other side of the lake. I have a temp guage on my boat but with the water runing backwards I do not think that it would have a correct reading as temp senser is located on the water outlet leaving the head of the engine. I am hopeing that maybe that when I ran the engine in reverse circulation that what ever was cloging the engine went back out and left the system. when I got home I hooked the water hose to the engine inlet and it seem to be flowing threw the engine. I can only hope that when I go back tomorrow that I will not have the problem again. Any advice will be apreciated. Thanks Robin
