DooGuy
Sorry for book but explains, figured would share incase someone might get something from this.
Right before the 4th, I hit a pretty good wake surf wave. About 30 seconds later oil alarm went off. Shut down immediately and checked fluids which both engines full and clean( oils was only month and half old)? started back up again and then felt engine vibration on starboard engine that wasn’t there before. Thought maybe sucked something as had a month earlier. Started going along and about 3,500 rpms oil alarm again. Repeated steps. Long story short limped back home and pulled it out, have been in slip. Got home and went thru steps. Pulled pumps. Tested spark thinking spark issue etc. finally after verifying electrical started thinking internal. Sucked the oil out and noticed what was looking new when I pulled out of water was now dark and glittery. Then I pulled the oil filter cap. The oil filter was crushed. Big o crap time. About this time I had to leave for two weeks and fix the house because we had scheduled paint crew and I had repairs I was doing. Fast forward. I pulled engine and pulled Pto. Oil sieve had silver and brass colored flakes, underneath was a whole lot of metal flakes. Likely a thrust washer/bearing let go. Inspected head and no damage indication anything made it up. Likely because run time from when alarm and tests was less than 15 minutes. Ordered a shortblock as don’t have time to mess with. Will keep as a winter project. I’m 3/4 thru assembly and hoping to have back in water Friday.
So at this point will see who’s still with me, The only thing I’m trying to still think thru is alignment when I drop back in. I left the motor mounts in figuring it’ll help. But still not sure yet as don’t have tool. Thoughts on how todo without the tool?
Only have two shops in town that I know of that work on these and they have 1-2 month wait times.
