DEADRINGER
Hi everyone. Got a old boat that ate some rocks last time out so gota re place a lot of parts. When I took it apart it was in a lot worse condition than I had hoped. One impeller shaft was rusted to the impeller and had a grove cut in it so did the other one. One of the other long shafts has some galling that barely catches on my nail. Would appreciate some expert advice.
1. Can the impellers be rebuilt? I know they do it with props what would it cost?
2. Should I reuse the shafts? They have a pretty good grove in them and the threaded part was really rusty and is a little lose when screwing together but tightens up fine. (pics)
3. The impeller case has some dings should I smooth those out leave them alone. Will it effect the pump?
4. There was a lot of black rtv around the pump housing is it a seadoo brand sealer? On the plastic pump cone there was a red loctite like sealer in around and on the o-ring area it seemed to seal well. Any idea what those two sealers were and where to buy more?
Further research shows that new impeller shafts have a grove in them??? whats that for?
