MY 2002 SEADOO SPORTSTER LE NO BEEP
stella
HI EVERYONE I HAVE A 2002 SPORTSTER LE. WENT TO START IT UP THIS YEAR AND NO BEEP WHEN I PUT THE HARNESS ON. ANY IDEAS?
Do the gauges light up when you hit the start button with the key off the post?
Did you try to start it even though it did not beep? Does it do anything?
You can start with the battery and get it load tested.
New Battery New terminals. No lights nothing. Sent some pics to a friend saw rust in where the coil and starter are from water sitting in it. I'll attach a pic. Going to unbolt everything and clean out the rust. This is the only thing different from last year. Don't think I'm getting a ground. Prayers
Nothing lights up and no it does not start even with no beep. New battery New terminals. added a pic on previous thread, but haven't had time to clean off the terminals in the starter box. ant other idea s will be appreciated. Thanks
Have you cleaned up the terminals? I would also still check the battery. New battery does not always mean good battery.
Yes cleaned Terminals also new battery. Starts when you cross solenoid and battery. But does not have any power to gauges as well.
