Ok well I bought this Sea Doo in 02 new and I have had absolutly no problems with it until this year.
When ever you drive it it fills up with water, the more you drive the more it fills up.
First I was worried there was a crack in the hull, but then I realized I was thinking nonesense considering I have always used in Lake George (fresh water) and it only has 59 hours.
So I then realized that when you leave it sitting it does not fill up with water, only when the engine is on. So I figured that a coolant line or somme must have broken. I then emptied out all the water with a wet/dry vac and turned the Sea Doo on in neutral while tied to the dock, I looked around and felt around for leaks and I found a bad leak under the exhaust hose, the hose had bursted, could this be becuase of a bad winterization keeping in mind it sitts out side in 0 degree weather?
But anyway I bought the correct hose, replaced the bad one, tighted it up and took it for a ride. Well it still filled up with water :rant: So i again emptied out the water, tied it up and turned it on, I just could not find any leak, could there be a leak in hoses under the engine, or could there be a crack in the engine itself, I have been pondering this stuff all week! Could someone tell me a good place to look, and is this normal because I can't figure out why this would happen with a Sea DOo with 59 hours while there are some with 500 hours still running.
Please Help
Thanks very much,
John
Please Help
Thanks very much,
John
