J jraglow Premium Member Premium Member Jun 7, 2018 #1 My 2000 Challenger Mercury starts and sounds good, but wont go
T Tim75 Well-Known Member Jun 7, 2018 #2 Lots of help available here, but need to be more specific. Engine type & model, RPM numbers, compression test, plugs out, at wide open throttle (WOT).
Dr Honda Well-Known Member Jun 10, 2018 #3 Yep... what he said. Did you look into the pump and make sure the impeller is spinning? Did you make sure nothing is stuck in the impeller? (a branch, or other small item will cause bad cavitation)
