First off Hi to everyone this is my first post, I recently purchased a running 1997 Seadoo SPX for £300 to do up as i have heard these are great ski's, I have previously owned a 1998 GTX 951 Limited 130hp bit heavy and more like a boat, So i sold it and brought a 1997 XP with the susspension seat was a little better but top heavy and a under powered due to weight. The SPX was going cheap and hopefully just what im looking for acording to peoples reviews. First thing it needed was a good clean but and running up, it was a little smokey as its been converted to premix and i think it had to much oil in the mix. Ok so i built a stand for it and got started on removing the engine to clean hull properly, I also removed head and RV assembly on engine to check the state of the pistons and barrels all seams ok. Next on the list is to De-coke Exhaust as its a bit sooty, clean out water ways and chambers with air compressor, fit new gaskets and rebuild carbs. Then on to the hull. here are some pictures of the progress so far. Thanks for reading and all coments are appreciated.
