Ozweego
This is my first boat and I made sure to do a sea trial and get a survey done. All checked out well. No issue on starting or running. Hit 55 mph, sounded good.
Bought the boat and immediately sent it for a fresh service. New spark plugs, oil and gear oil. Had an inspection done and got two recommendations. Oil sensor needed replacement, will give audible beep every 4 mins or so. Part ordered. Second was the exhaust hose needed replacement, also ordered. Other then that shop gave it a pass. Due to it being a couple of weeks before new parts arrived they advised me the boat will function normally (albeit with annoying beeping) for the time being.
First day out on water after service, everything was good. Took 3 tries to start but fired up. And ran well.
Second day, took approximately 10 key turns to get it running. This was discouraging. Anyone else have this issue? Is there something the service center missed? I just want to make sure I get the required work done and do my best to Make this boat last.
Not sure if the missing oil sensor is to blame or not. Any advice would be appreciated to this first time boat owner.
Thanks
Thanks
