Muffler leak
Skitchim
Hello, I just bought a 2008 Challenger 180 215hp and noticed a bit of water spraying from what I thought was the small hose on the top of the muffler. Upon further investigation, the water is coming from a small (maybe 1/2 inch) slit right underneath. Only causes issues when the electronics get wet (understandably). My question is what is the best solution for this? I was thinking about using a high temp, high pressure type of putty. Any one had this issue before, or any advice? Thanks.
I'd pull the muffler and take it to a welding shop. Permanent fix. Not too expensive, either.
