Scotttheimpaler
I have had an excessive smoke issue or some time, specifically starboard side. I replaced the spark plugs and port side temp sensor, no change. I tried the boat this weekend and noticed that port side exhaust has no heat, just some slight moisture spiting. After reading some posts, and doing some searching, I got an inline spark detector. I found that the top spark plug on each side has no spark. No current is going to the plug. I need advice instead of buying a trigger, ignition controller, CDM Module assembles for $1300.
Thank you all,
Scott
Thank you all,
Scott
