Ckrawiec
A pointer to the MPEM diode replacement instructions would be appreciated. I keep having a 12V low problem (I think) with the ski....everything else checks out that I can determine (stator output is good), but I'm not definitively convinced that I'm getting 14.4 V dc back to the battery (consistently) when it runs.....sometimes I hook up the meter to the battery with ski running and I get a nice voltage greater than 12.6 to 14.4...but other times its all over the place (jumping erratically).
The ski will be hard to start (some times) but it always wakes up on a button push. My buzzer is shot (I know, I will fix it as soon as I can...ski is out of the water at the moment but 3 hours away). Attaching the DESS key and hitting the S/S button always gets her cranking/turning over but sometimes it'll catch and start, sometimes not.
As it is trying to start, I will get a 12V low message...but once it does start the 12V low message then goes away along with the yellow warning light.
I have a love/hate relationship with this ski.....I want her to be reliable again, because when she does run, she is a beast on the water....strong, stable, fast.....but there is always that nagging feeling that you just don't want to shut her off mid-water as she may not re-start (she always has but still a little concerning).
I don't know if the MPEM diode is bad just yet...but I'd like the info in my back pocket IF I need to go there.....I know I've seen/read about this on the forum before.
I've been in there already, plastic check valves and gaskets are all in place, and squeeky clean.....but I'll be double/triple checking again (for S & Gs)
