chariotdriver
This should be fun and I'm not sure if it's legal, but here goes.
I loaned my skis out and when they came back after a few days the 96 GSX has a hole burned in the MPEM and won't work. Something shorted out and the folks replaced the 5A fuse with a 15A fuse; what the heck! Traced the short to the single purple wire going into the brain box then swapped the whole MPEM with the one from the 97 and it ran fine. Now I find out how much they cost plus reprogramming and I'm thinking "not so much."
My question is what is required to bypass the MPEM? I know I need a white wire from the ignition module to the coil to make it spark and the yellow runs the starter solenoid and timing comes from the front via the magneto system. I'd like to run the start stop switch for just a start function and use the DESS key (with a shunt inside) to close the relay to power everything. What all does the ignition module get from the MPEM besides power? Does the ignition module have a brain which needs to be unlocked as well? I know the gauges, beeper, etc won't work but the boat is getting pretty old to be dumping a bunch of coin into it.
thanks for any help, cd
