i have read lots of post and cannot find how to fix my problem... i have an 98 speedster with two 110hp motors... the driver side motor works but runs ruff outside the water but once i have it in the water under a load it idles then boggs out after a couple of min.... if you give it gas it will also die.. after a while if it will not start at all...when we take it out the water it will have lots of water coming out the intake when its started..
things we have done to fix the problem:
rebuild the carb, new spark plugs, new gas lines,new fuel filter..
i have also found out there isn't a good spark coming out of that engine ,someone suggested there may be a bad coil.
any suggestions please let me know or if you are in my area and may be able to help...thanks alot
